Non-SSL and Non-Fully Qualified URL for Job Summary
  • June 11, 2021
  • 13 views
When I receive emailed server error notifications they are formatted like
Job 334: http://SERVERNAME:443/fmeserver/#/job/334/summary
rather than the proper SSL and fully qualified configuration. Once I change the URL to
Job 334: http://SERVERNAME.FQDN.com:443/fmeserver/#/job/334/summary
it resolves properly and I can access the log.
My question is, where do I change this setting permanently? All of the URL's in System configuration are set correctly. Is it a configuration file setting? If so, can someone point me to the correct file to modify?
Best answer by hollyatsafe
Hi @mmirobelli​ ,
Please update the FME_SERVER_WEB_URL in  fmeServerConfig.txt located in <FMEServerDir>\\Server\\.
  • June 11, 2021
Hi @mmirobelli​ ,
  • June 11, 2021
Hi @mmirobelli​ ,
Thanks! I made the change. I appreciate the fast reply and the assistance. :)
