How to un-install a package from FME Server
  • November 27, 2020
  • 97 views
alex_c
Participant
A package in the form of a fpkg file was installed during the upload of a new workspace. How can the package be uninstalled from FME server
Best answer by sanaeatsafe
Packages can be manually managed and removed from Resources, accessed from FME Server's side panel under Files and Connections. Pictured below is the location on my own FME Server, yours may appear slightly different depending on your OS.
2020-12-02_11-29-25From here, select the package and choose 'Remove' from the Actions drop down menu.
Hope that helps!
sanaeatsafe
Forum|alt.badge.img+8
  • December 7, 2020
Hope that helps!
