WFS to FileGeodatabase
  • November 28, 2013
  • 21 views
Hi Folks,
It is very simple question but still I need some suggestions;
I created a workbench that downloads WFS, reproject it and save it in File Geodatabase in the local Geodatabase folder. We would like to use same workbench multiple time (lets say may be once a month), but the problem I am having is, it works perfect for the first time but when I try to use same workbench for same WFS file (a month later date data), I change the parameter (destination folder for another copy) the massage I get is
"Translation was SUCCESSFUL with 1 warning(s) (0 feature(s) output)" Can anybody point me out what am I doing wrong? Since I am downloading same data from same WFS link, I don't do anything on Reader parameter :)
  • November 28, 2013
The message is saying a warning occurred. The warning message contains a hint about the unexpected result?
Takashi
  • November 28, 2013
Takashi is right, have a thorough look in the log file to see where the warning occurs. Feel free to post the offending line(s) it here.
David
