FME Server fails to run functioning workspace
  • April 30, 2018
  • 15 views
I have a workspace that runs correctly on FME Desktop, but when I run it on FME Server it fails. I am new to FME Server, but feel like I have set things up correctly after viewing the tutorials several times.
Attached is a log file for the failed workspace run. Any help would be greatly appreciated.
Thanks
laurawatsafe
Forum|alt.badge.img+13
Hi @joeyb2018
The error message in that logfile looks similar to the second error mentioned in this troubleshooting article: https://knowledge.safe.com/articles/363/workspace-fails-on-fme-server-fme-version-incompat.html
Does the version of FME Workbench that was used to create the workspace match the version of the FME Server where it is failing?
