ESRI Geodatabase (ArcSDE Geodb) Reader for FME Server
tbs_gis_team
I am trying to publish a workspace to FME Sever with the
ESRI Geodatabase (ArcSDE Geodb) Reader and when I run the process it gives me the following errors:
1. The Esri Product license used by this machine does not include licenses for the 'Advanced' licensing level.
2. Unable to perform any licensing related tasks. This is a 64-bit version of FME which requires a 64-bit version of ArcGIS Server. Or download and install a 32 bit version of FME. Refer to this this article http://fme.ly/qua for more details
Do I need to install an advanced license on the server or is it missing DLL files that I can load on the server with the FME process?
Thanks,
Chad
philippeb
Forum|alt.badge.img+18
  • August 27, 2018
It seems you have a problem with your versions.
Which versions are you using FME Desktop / ArcGIS Server? 32 or 64 bits?
You have installed ArcMap on the server right? Not ArcGIS Pro?
stalknecht
Forum|alt.badge.img+19
  • August 27, 2018
Ensure that your ArcGIS installation is on the same machine as the FME installation and use the ArcGIS Administrator application to check the availability of ArcGIS licenses.
For FME Server, setup the user account running the FME Server Engines Windows Service to use an account with 'Administrator' level permissions. The FME Server Engines must be restarted for any changes to take effect.
please take a look at: https://knowledge.safe.com/articles/24153/using-fme-server-with-esri-software.html
  • August 27, 2018
Also, please read the following carefully, especially if you're using 64-bit FME:
https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
tbs_gis_team
  • August 27, 2018
ArcGIS Pro 2.0 is currently installed not ArcMap, ArcDesktop Geoprocessing 10.5.1 is currently installed.
Current account running fme services is “LocalSystem” should this be changed to a user named account with admin privileges on the machine or tied to a user domain account.
Currently running FME Server 64bit(2017.1.0) and ArcGIS Server 10.6.1 64Bit (recently upgraded). Does the Arcmap Desktop installed on FME server require its own license for Arcmap (standard or concurrent)?
Thanks,
Chad
philippeb
  • August 27, 2018
Thanks,
Chad
And everything works fine when you run the workbench?
Maybe you should try this : https://knowledge.safe.com/questions/60075/fme-desktop-64-bit-using-arcgis-pro.html
And this : https://knowledge.safe.com/questions/42891/can-fme-extend-into-arcgis-pro.html
