how to change the publish parameter values for each run in fme server ?
  • March 14, 2018
  • 70 views
f.kemminje
Forum|alt.badge.img+11
Hi Team Fmeiers,
I wanted to change the publish parameter value in fme server for each run. for example
existing system we have is:
fme desktop,in my fmw file the buffer value is published. and every time i run thru batch file, i can change the buffer values by editing batch file.
fme.exe c:\\temp\\create_road.fmw --buffer 50
fme.exe c:\\temp\\create_road.fmw --buffer 100
fme.exe c:\\temp\\create_road.fmw --buffer 150
here the bat file calls the same fme workspace three times with different buffer values.
calling this batch file windows scheduler , three different time intervals.
upgraded to fme server 2017
Now, this fmw file is published in fme server and this job is scheduled in server three times a week
how can I achieve the same task using fme server.
your help will be appreciated.
Best answer by david_r
The easiest is to create three different schedules, one for each buffer size.
Next step could be to chain the workspaces together with e.g. a master workspace and three FMEServerJobSubmitters with different buffer sizes. You can then create a single schedule for the master workspace.
The black belt solution is to do the same thing using notifications :-)
  • March 14, 2018
oscard
Forum|alt.badge.img+22
  • March 14, 2018
You could also code an app to run the fme server workspace with the parameters you want:
https://playground.fmeserver.com/
