Read CSV file fails to read or is missing columns
sunsilk11
Hi I am trying to read attached CSV file using FME 2020.1 Can some pls advise the correct parameter on the reader to all the values from this csv file.
I have tried various options. It either doesn't read it at all, or misses few columns
Best answer by rahulsharma
Hi @sunsilk11​ It appears that there is something going wrong and I was able to repro the behavior that you explain. I will file an internal issue to get this investigated and will keep you posted.
rahulsharma
Forum|alt.badge.img+10
  • December 4, 2020
rahulsharma
  • December 7, 2020
Hi @sunsilk11​
The issue is now resolved in FME Desktop 2021.0. Are you able to update to the 2021 betas?
trentatsafe
  • December 7, 2020
rahulsharma wrote:
Hi @sunsilk11​
Also looks to be working in latest 2020.2 Build 20806. If you would prefer to not use a beta.
