Attribute Manipulation : Splitting a list at discontinuities
How do I retrieve the lowers and uppers bounds in a discontinuous list of values (alphanumeric)?
Example of list: {5, 6, 7, 8, 10a, 11, 15, 16x, 17, 18, 19, 20, 25}
The extraction I'm looking for would be: 5-8, 10a-11, 15-20, 25
Thank you
  • February 27, 2017
I'm sure this can be done using transformers, but I suspect it'll be rather convoluted. Here's a possible solution using a PythonCaller:
import fmeobjects
from itertools import groupby
from operator import itemgetter
def str2int(s):
    return int(''.join([x for x in s if x.isdigit()]))
def split_list_at_bounds(feature):
    data = feature.getAttribute('values')
    if data:
        data = [x.strip() for x in data.replace('{''').replace('}''').split(',')]
        bounds = []
        for k, g in groupby(enumerate(data), lambda (i,x):i-str2int(x)):
            bounds.append(map(itemgetter(1), g))
        for n, boundary in enumerate(bounds):
            if len(boundary) == 1:
                s = boundary[0]
            else:
                s = '-'.join([boundary[0], boundary[-1]])
            feature.setAttribute('boundary{%s}' % n, s)
Assuming the input attribute values = "{5, 6, 7, 8, 10a, 11, 15, 16x, 17, 18, 19, 20, 25}" it will output list boundary{} like the following:
The grouping mechanism in str2int() will strip away all non-digits, so be careful if you have values like 12x3 as it will be interpreted as 123 and not 12.
Forum|alt.badge.img+31
  • February 27, 2017
Forum|alt.badge.img+19
  • February 28, 2017
A geometric approach could also be an alternative.
  • February 28, 2017
I am admiring the flexibility of this tool and the genius of its users.
Thank you
  • February 28, 2017
I need a little time to test all these solutions. Thank you
  • February 28, 2017
Performance-wise, I would expect the Python-solution to be the fastest by quite a margin, followed by the solution from @egomm. The suggestion from @takashi is really cool and a great demonstration of the flexibility of FME, but I suspect it is relatively slow if you have a lot of data.
  • February 28, 2017
Very cool.
  • February 28, 2017
The geometric approach is interesting and demonstrates the flexibility of FME, but its performance is not good as @david_r pointed it out. If the performance is critical, I would not recommend you to use the geometric method in the practical workspace, and consider adopting the Python solution.
