SAML option missing in FME Flow Connection parameters in Form
  • August 19, 2024
  • 67 views
jonvelco
Running 2023.2 (both Flow and Form) and I have SAML setup, configured, and working on Flow.  However, in Form, when I add a FME Flow Connection - the SAML drop down under Authentication is missing even though the documentation says it should be there.
What am I missing??
Missing SAML option in Authentication drop down
FME Flow:
Our FME Flow site with SAML enabled
Documentation:
Documentation
Best answer by jonvelco
Answering my own question...it’s hidden under the “Use Alternate Login Method”
jonvelco
  • August 20, 2024
