FME 2020: How to select polygons (areas) that contain more than point?
jamal
Forum|alt.badge.img+5
FME 2020: How to select polygons (areas) that contain more than one point?
I couldn’t figure out how to select polygons (areas) that contain more than one point. For example, in the screenshot below, I got just two polygons that contain more than one point. How to get them identified and selected?
Clip_283
Best answer by nielsgerrits
One way to do this is to use a PointOnAreaOverlayer, Area outputport, Tester _overlaps > 1.
You can also use a SpatialRelator and test for _related_candidates > 1.
nielsgerrits
  • January 29, 2021
jamal
  • January 29, 2021
Thank you very much nielsgerrits for the help. It works fine
Clip_288
Clip_289
