oAuth refreash token screen blank
  • April 29, 2014
  • 21 views
nrich_defra
I've just been trying to play with the google engine api, and the FME 2014 reader/writer functionlity.
I'm stuggelling a bit with the oAuth refreash token.
the dialog that FME provides is blank, (white and empty) so I can't use it to generate a token for me, so.
1) can some one debug why my dilog is empty (i suspect proxy issues, i have set my paswords in the tools>options)
2) how can i generate a code to paste in to here outside of FME....
and maybe
3)  ideally this would be for deploying onto server in the end, what ports do I need open to support oAuth and googles spatial engine.
Nick
nrich_defra
  • April 29, 2014
I get an error after a while to when trying to open the oAuth dialog:
"Network Error: Unknown network-related error was detected"
  • April 29, 2014
that sounds more like a network error than an FME issue. Could you perhaps post some screenshots of what you're trying to do?
David
