Where should I place MyCoordSysDef.fme on FME server 2016.1?
What's the location for my custom projection file on 2016.1?
Best answer by erik_jan
Hi Wilko,
The Reproject folder in the FME install is still available to contain your custom projection file.
If you copy it to that location FME will be able to use the reprojection.
Erik Jan
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
