FME Server can't find license
  • June 12, 2014
  • 5 replies
  • 33 views
swach
I have a workbench that contains two FMEServerJobSubmitters which run based on an attribute value. When I run the process within server with the attribute vale of 'X' the correct server workspace runs and finishes successfully. When I use the value 'Y' it gives an error that no FME floating licenses are available.  Processes X and Y are identical, they are taking data from SDE and clipping it to output to shape and dwg, just using different data.  When I run the original workspace from the desktop everything runs successfully.  Why would one part of this process give a license error and not the other part?  I don't have any problems with licenses running any other processes.
fmelizard
Forum|alt.badge.img+21
  • June 12, 2014
Sounds like a case for Support....
gio
Forum|alt.badge.img+15
  • June 13, 2014
seems like proces X is not finished when starting proces Y.
Like 2 persons trying to use 1 license.
On the desktop you can run mutliple instances on 1 license. On server not (if i'm not mistaken that is..)
swach
  • June 13, 2014
Either X runs or Y runs, never both.  They shouldn't be interfering with each other.
gio
  • June 13, 2014
ok, that seem not right then... as Itay said.
(You are not viewing/inspecting the result i assume, thats takes a license as well.)
swach
  • June 13, 2014
I sent the case to Support.
