How do I set license level in FME?
  • December 17, 2019
  • 160 views
The ArcObjects license 'Advanced' is being selected from the ESRILicenseInfo ArcObjects call
The Esri Product license used by this machine does not include licenses for the 'Advanced' licensing level
Unable to load a library in the folder: C:\\Program Files\\ArcGIS\\Pro\\bin. The error number returned from GetLastError is: 127
jovitaatsafe
Forum|alt.badge.img+11
Hi @jamesnjarvis,
The error reminds me of this answer from another Q&A, where Annabelle suggests that this error might occur when installing new versions of ArcGIS without removing old versions of background geoprocessing. There are a few other ideas in that thread that might be helpful as well. Please give that a look and let us know if it works for you!
