Downloading Resources from FME_SHAREDRESOURCE_DATA
  • December 5, 2024
  • 74 views
oscard
Forum|alt.badge.img+22
Good morning.
According to this article I should be able to download resources using an URL similar to:
https://fmeserver.example.com/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_TEMP/filesys/testSpreadsheet.xlsx
But when I try to do so, instead of getting the file I get information about the file:
http://sigdesafme.dfa.es/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/GASTDM01/wrapper.log
What I get in the web explorer is this: {"date":"2024-07-17T13:04:52+02:00","path":"/GASTDM01/","size":153839356,"name":"wrapper.log","type":"FILE"}
Am I missing something?
I have tried to change filesys for “download” or “downloadzip”, but the ZIP it downloads is empty.
The version of FME Server is 2021.1.
Best answer by siennaatsafe
Hi ​@oscard,
Try adding ?accept=contents&disposition=attachment to you URL. Like this
http://<URL>/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/PublicTrees.csv?accept=contents&disposition=attachment
I think the accept parameter is the key to getting this to work in a URL.
I found this in the REST API Docs on a 2021 Flow instance go to http://<YourFlowURLl>/fmerest/apidoc/v3/#!/resources/download_get_10 to access this documentation.
Hopefully that helps!
siennaatsafe
Forum|alt.badge.img+12
  • December 6, 2024
Hi ​@oscard,
oscard
  • December 9, 2024
Hi ​@oscard,
Thanks! That worked!
