Merge 2 files geodatabase
  • May 31, 2021
  • 90 views
hugues
Hi. I have to load a lot of FGDB in another one. The file geodatabsae have the same schema.
Can you help me
Thank.
danilo_fme
Forum|alt.badge.img+53
  • May 31, 2021
Hi @hugues​
Did you use the transformer FeatureMerger?
Thanks in Advance,
Danilo
hugues
  • June 1, 2021
I'm not sure. I don't have field to make any join. It's more like append that i have to do.
nampreetatsafe
Forum|alt.badge.img+13
Hi @hugues​, if you're looking to append multiple datasets with the same schema try connecting the reader feature types (data sources) to the same destination like so:
2021-06-01_23-39-37
