ERROR: WORKSPACE GENERATION FAILED
  • May 24, 2023
  • 298 views
vimva679
Forum|alt.badge.img+9
Hello am running my FME workbench on one of my colleagues system with FME trial version (without ArcGIS) and I have full FME 2022.2 version(ArcGIS installed on system).
Getting this error : Parameter file was ..... any workaround that FME workbench to run without ArcGIS.
Best answer by nielsgerrits
Change the Python compatibility from Esri ArcGIS Python 3.6+ to Python 3.6+.
You can find this in the Navigator, Workspace Parameters, Scripting, Python Compatibility.
nielsgerrits
Forum|alt.badge.img+64
  • May 24, 2023
vimva679
  • May 24, 2023
thank you for your quick response :)
nielsgerrits
cheers :)
