Error during SSL(HTTPS configuration for FMEServer
  • February 27, 2019
  • 5 replies
  • 48 views
Hello.
I have a hard time with SLL configuration.
I was following this Configuring for HTTPS
I finish all steps without any error messages, however, when I try to open FMEServer by using HTTPS I receiving an unsafe window error
I have also edited all files as it was shown in the above-mentioned guidelines. Certificated also were added
in the windows trusted certificates list.
I am non-SSL guy but can the problem be that the installed certificate cipher suite "AES_128_CBC " is an old version and must be replaced with new "AES-GCM" cipher suite? I have marked the message about this on my unsafe error screenshot.
How can I fix this?
I am using FMEServer 2019.0 (19212) Beta and Google Chrome
Thank you for your help in advance.
  • February 27, 2019
In your screenshot it says that the certification path is "fmeserver.example.org", surely that cannot be right?
  • February 27, 2019
Hi David
How the proper path structure should look like?
For this particular case, I used from the guideline.
  • February 27, 2019
Hi David
I am by no means an expert, but I suspect that you should use your proper server name, not the example name.
  • February 27, 2019
I have tried many different path examples without any success :(
It would be very helpful if HTTPS would be supported by default.
Anyway, thank you very much for your help.
laurawatsafe
Forum|alt.badge.img+13
Hi @linkas
Just to check, are you following the steps for configuring a self-signed certificate for FME Server?
From looking at the screenshot you provided, I believe @david_r is correct that the hostname set within the keystore file that you create in step 1 of those instructions should be the hostname that you would use when connecting to the FME Server web interface in a browser. It does look like you have most of the other configuration settings set up correctly as FME Server is recognizing that you are using an SSL certificate. So, I think the issue is mainly with the certificate itself.
If you're still having trouble with this, would you mind sending us a support case through: https://www.safe.com/support/report-a-problem/ We can help you dig into this a bit more.
