Using arcpro liscence to open gdb
  • March 15, 2019
  • 27 views
Hello, So I have an issue. I'm trying to run a workspace at work but there ar no standard arcgis licences avialable. So fme tries to use the arcpro licence. It gives this error: Unable to load a library in the folder: C:\\Program Files\\ArcGIS\\Pro\\bin. The error number returned from GetLastError is: 127
Arcpro is set to work offline and there are plenty licences available. Anyone has an idea of what might be the issue. Also, arcgis 10.6.1 is installed with the right version of background geoprocessing and the version of arcpro is 2.3.0. Thanks,
Simon
  • March 15, 2019
Hi @simon_fb, make sure that your ArcGIS Desktop license is active.
FME requires ArcGIS Desktop license to process Esri Geodatabase formats, even if you would use ArcGIS Pro for 64 bit background geoprocessing.
