Fuzzy String Comparer
bubblebeb
Does anyone know if the FuzzyStringComparer has compatability issues with 2017.0?
I am getting the following error in the log when trying to use it.
2017-04-26 13:37:48| 0.3| 0.0|ERROR |Python Exception <AttributeError>: 'float' object has no attribute 'lower'
2017-04-26 13:37:48| 0.3| 0.0|ERROR |Error encountered while calling function `FuzzyStringCompare'
2017-04-26 13:37:48| 0.3| 0.0|FATAL |f_9(PythonFactory): PythonFactory failed to process feature
If it is an issue with compatibility, is there another transformer I can use to do the same thing?
Thanks
  • April 26, 2017
Could it be that one of your attributes contains a float rather than a string?
Try forcing the attributes used by the FuzzyStringComparer to strings using a format string of "s", e.g.
bubblebeb
  • April 26, 2017
Thanks David_r
I have tried that but without success.
The message I get now is
2017-04-26 13:49:30| 0.3| 0.0|ERROR |Python Exception <AttributeError>: 'long' object has no attribute 'lower'
2017-04-26 13:49:30| 0.3| 0.0|ERROR |Error encountered while calling function `FuzzyStringCompare'
2017-04-26 13:49:30| 0.3| 0.0|FATAL |f_11(PythonFactory): PythonFactory failed to process featur
Thanks
  • April 26, 2017
Did you send both your attributes through the StringFormatter? These two:
  • April 26, 2017
You can also modify the two lines in the PythonCaller of the FuzzyStringComparer as follows:
    string1 = str(feature.getAttribute('FuzzyStringCompare.string1'or '').lower()
    string2 = str(feature.getAttribute('FuzzyStringCompare.string2'or '').lower()
This will accomplish about the same thing.
bubblebeb
  • April 26, 2017
I will give it a go
Thanks
itay
Forum|alt.badge.img+17
  • April 26, 2017
You are not the first to note that there are issues with the transformer:
https://knowledge.safe.com/questions/43217/fuzzystringcomparer-many-versions-many-issues.html
maybe somebody from Safe can provide some info on the matter....
  • April 27, 2017
Agree. The current FuzzyStringComparer raises an error if a specified attribute contains a non-string type value, or the attribute is missing. The code provided by @david_r would a quick workaround, but I think there still is a room to improve.
  • Casting to str instance could cause an error, if a specified attribute contains a unicode instance representing a character incompatible to ascii code. The error occurs only with Python 2.7, won't occur with Python 3.x.
  • If a specified attribute contains numeric 0 (int or float value), the right hand side of the expression returns the empty string since the numeric 0 as an operand in a logical expression will be interpreted as False by Python interpreter.
@RylanAtSafe, please consider doing further improving ;)
  • April 28, 2017
Definitely needs cleaning up to catch those special cases, yes.
