FME form trying to create a folder when it should create a file
  • May 9, 2025
  • 102 views
fmejohn93
This job works fine in FME Workbench 2024.2. But in FME flow, when I try to run the workspace, it’s trying to create a folder instead of a .xml file. See screenshots
Best answer by crutledge
Oooooh ​@fmejohn93 Make sure the file path is full UNC \\woozle.wuzzle.intra\mystuff\morestuff\
crutledge
Forum|alt.badge.img+44
  • May 9, 2025
Hi ​@fmejohn93 Does the before part of the path (blacked out) exist? Maybe your Flow User Account does not have the rights to create a folder/file in that location. say c:\Program Files\****\ConfigExportFme.xml or something like that?
Hope that helps.
Does the folder structure exist?
fmejohn93
  • May 9, 2025
Thanks for your response. Yes, I’ve verified that the path exists and that our Flow user has permissions to write to that folder.
crutledge
  • May 9, 2025
fmejohn93
  • May 12, 2025
That worked! I was missing the full UNC
