Change Automation Directory Watch Poll Interval
  • March 8, 2025
  • 15 views
vxn43
Forum|alt.badge.img+18
I am using FME Flow 2021.2.
Is there a way to change the Directory Watch Poll Interval in an Automation to trigger only Monday through Friday, 8 a.m. to 5 p.m.?
Best answer by hkingsbury
I think, within the Automation trigger, no, you can only specify the polling interval.
You could look at active periods in your engine assignment rules and have a period that only assigns engines to that queue during those hours. This will mean:
  1. There needs to be a job routing rule that routes that workspace to a specific queue
  2. The jobs will get submitted, and sit in a queue until the active period begins
hkingsbury
Forum|alt.badge.img+54
  • March 9, 2025
