I get this message when I want to create a Scedule on the server. Then this message pops up even when I filled all parameters and I do not see any (typing) error.
“Some or all of the input parameters are invalid” when I want to create a scedule. Then I cannot do anything else instead of starting from the beginning.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
