Upload to Sharefile.com
  • April 1, 2024
  • 86 views
klingdom
Forum|alt.badge.img+5
Hello,
Does FME have a transformer or does HTTPCaller support Uploading to Sharefile.com.
I have setup an HTTPCaller to authenticate then a FeatureRead to get the zip file then an HTTPCaller to POST and upload.  In both cases I get _http_status_code 200 but no upload.
Thanks for any help,
hkingsbury
Forum|alt.badge.img+67
  • April 2, 2024
HTTPCaller will be able to achieve that. You’ll need to look through the API specifications for that service (https://api.sharefile.com/) and determine what calls you need to make to achieve what you’re wanting to do
