Put output of an XSD Driven XML Writer into a attribute instead into a file.
hasant1973
Forum|alt.badge.img+3
I use a XSD Driven XML Writer to compose a XML file.
Afterwards I read the file and send it with the HttpCaller to a SOAP Endpoint of some application.
Is is possible to skip the "Save to File" "Read from File" part and directly write into a XML attribute of some feature?
nielsgerrits
I do not know of a way. What I do is write the file to a temp location using a TempPathnameCreator to avoid temp files which need to be deleted afterwards. But you still have the extra I/O you probably want to optimize?
hasant1973
  • July 5, 2023
The FeatureWriter looked promising to me and I tried setting up a "XSD Driven XML" inside the FeatureWriter. But it also requires a file ("dataset") where the data is stored. Could not discover any settings where I could let it write the xml into a output of the transformer component.
nielsgerrits
Not sure if I understand what you need, but the DataSet can be an attribute or concatenated attributes. For example
@Value(_pathname)\result.xml
