Hi, I run a FME workspace every morning using task schedular on my computer. The data I am outputting is as an excel spreadsheet. Is there a way for the excel spreadsheet to be named the date the FME workspace was run?
  • December 18, 2023
  • 23 views
I already have a date field in the excel spreadsheet. I think I am just missing how to set up the parameters. Please let me know 😊
Forum|alt.badge.img+62
You can set up a Fanout in the Navigator, see this thread for some more info. If you have a data field already (and you're not running this workspace around midnight 😅 ) you can use that attribute in the filename.
