I have points and lines features, I want to snap the lines to the points, both edges ends, and sides, etc.
  • December 3, 2022
  • 54 views
cnero101
I have points and lines, I want to snap the lines to the points, both edges, ends, and sides. I tried using the snapper and also tried using the anchored snapper, but I still don't get to snap some. I have used intersection transformer, it does the major part of the snapping but creates new points at any intersection without a point. I really would love to do this snapping based on relationship (attribute)
  • December 6, 2022
@cnero101​ If you can include a small sample dataset with a diagram of what is not working for you then contributors might be able to help a little more
