Are automations being cached in FME Server 2020.1 - when I make changes to run until cancelled from on to off this is ignored.
  • November 30, 2021
  • 22 views
I have an automation in FME Server 2020.1. I changed the workbench being triggered advanced setting from run until cancelled so that it is no longer checked but this change is being ignored and the log shows that it is still using that setting. Perhaps this is being cached? Anything I can do to force the change to be applied?
Best answer by bibold
I resolved this - no caching - I just needed to cancel the previous jobs. Thanks.
  • November 30, 2021
