What is the best way to interrupt the start of a workspace in the automation chain?
  • March 28, 2022
  • 43 views
aguan
Forum|alt.badge.img+11
Suppose I have two workspaces A, and B that run sequentially in a scheduled job. I want to start B if A actually runs through and writes something to the writer. If nothing writes in A, I don't want B to start at all. I could think of a few ways to do it, but all require writing intermediate status data to an external file or database. Should there be a simpler way to do this in the FME server automation (I am at 2021.1.2)? Is it possible to do this in the startup python script - if a condition is not met, terminate the workspace?
Best answer by david_r
The easiest is to simply to use the Terminator transformer in the workspace, which will trigger the Failure output port of the automation action, rather than the Success output port.
  • March 28, 2022
aguan
  • March 28, 2022
@david_r, that is no more simpler. Thanks.
