Error with emailer (FME desktop)
fmenco
Forum|alt.badge.img+5
I'm trying to send an email (to myself) after a succesful translation. I implemented the steps mentioned in the link (with the featurewriter, sampler etc) by @aaronkoning :
https://knowledge.safe.com/questions/4963/sending-mail-in-fme-desktop.html
However, eventhough the translation itself is succesful, the email apparently gets rejected (see image), and in the inspector 17, I see the following error:
Fme_rejection_code: ERROR_DURING_PROCESSING
(don't mind the lack of output from the featurewriter, I was playing around with it just before screenshotting. It generates input just fine).
What am I doing wrong? I'm using FME Desktop version 2018.1.0.1.
Best answer by david_whiteside
What does the log file say?I've seen this error before when you aren't authenticating in the Emailer.
The log file should give you more of an idea.
  • May 29, 2019
Sounds like it could be a problem with the SMTP server. What happens if you create a dummy workspace that contains nothing more than a Creator -> Emailer?
I also agree with @david_whiteside about having a good look at the log file.
fmenco
  • May 29, 2019
@david_r
@david_whiteside
Update: It worked when authenticating!
This is what the logfile said about the emailer without authenticating:
Emailer (Emailer): Potential network issue. Retrying SMTP connection, attempt 1 of 2
Emailer (Emailer): Potential network issue. Retrying SMTP connection, attempt 2 of 2
Emailer: <class 'smtplib.SMTPServerDisconnected'>: Connection unexpectedly closed
Now I know that I just need to authenticate. Thanks for the help
