Is it possible to send emails to [name]@[subdomain].[domain].com?
jtermaaten
The mail address I want to send mails to is in de format [name]@[subdomain].[domain].com. The emailer shows the following error. Is this a known bug?
Emailer: <class 'smtplib.SMTPDataError'>: (503, '5.5.2 Need rcpt command')
Thanks in advance
  • May 3, 2018
The error message looks more like a server error, I doubt it has something to do with the email address.
Are you certain that the server specified in the Emailer is actually running an SMTP server?
jtermaaten
  • May 3, 2018
Thanks very much for your quick response. When I test the workbench with my own email address as recipient, everything works smooth. Testing the recipient email address from Microsoft Outlook results in an error message back, sent from the recipient server. That's why I expected the workbench to proceed correctly, resulting in an error message back at my own email address from the recipient server. FME, however, stopped before it sent the message.
philippeb
Forum|alt.badge.img+20
  • May 3, 2018
Do you have a firewall in your environment?
jtermaaten
  • May 4, 2018
Ah, good one. I tested again, this time with my private email address and FME returned the same error. Is there an easy solution, or should I contact the IT department of my company?
  • May 4, 2018
You may have to contact your IT dept, but it depends on what you're able to do yourself on the FME Server instance.
Basically, you'll need admin login on the server and follow with steps here:
http://docs.safe.com/fme/2018.1/html/FME_Server_Documentation/Content/AdminGuide/Using_FME_Server_with_Proxy_Server.htm
