I have a shapefile that contains about 10'000 points and need to merge some data from a polygon shapefile that describes administrative areas. I need to add the relevant admin area data to each point.
Is there a way to do this in FME?
Best answer by nielsgerrits
Multiple ways to do this:
You need to check the Merge Attributes checkbox.
