Topological Error like overshoots ,undershoots and pseudo node
  • March 16, 2017
  • 9 replies
  • 233 views
gis2020
Forum|alt.badge.img+5
Hi All,
I have road network where in i want to find the the overshoots,undershoots and pseudonode in network.
I have tried to build the topology using the topology builder but note sure about other transformers which can be used to do this. I have done this in arc but not in FME.
Can some body help me to find the correct transformer to do this task in FME.
Thank you in advance :)
  • March 16, 2017
itay
Forum|alt.badge.img+18
  • March 16, 2017
The other option would be to use the MRF transformers.
  • March 16, 2017
Agree. They're expensive, but in my experience they're well worth it when the going gets tough.
Link: https://www.safe.com/solutions/specialty/mrfcleaner/
gis2020
  • March 17, 2017
Hi David,
Thank you for suggesting the smartcleaner.
smart cleaner is cleaning the geometry but in my case just want to identify the error i dont want to repair them. so i am using few transformer form smart cleaner to do this with some changes. so far i have succeeded with identifying the overshoots. for this I am building the topology and then using length calculator for calculating the length for each segment of the network and then a tester which has a set tolerance/distance for overshoot to filter out overshoot segments and illustrative WB for overshoot identification.
But struggling to identify the undershoots now.Any help on this
thank you in advance :)
gis2020
  • March 17, 2017
I have read about the super cleaner but not sure about how i can integrate it in FME.
  • March 17, 2017
What if using the Smartcleaner first and then put cleaned and original through the ChangeDetector?
Then "Added" and "Deleted" are the identified error locations.
  • March 17, 2017
I agree with @webklaas about considering the ChangeDetector or similar.
Another option to detect undershoots would be to use the LineExtender followed by an Intersector to see if the number of intersections change, which would indicate a possible undershoot.
  • March 17, 2017
You would have to buy a separate license for the MRFCleaner transformer family, see the link I provided above.
gis2020
  • March 20, 2017
Thank you David .I will surly try this. :)
