i have two sets of data: a lidar point cloud and dgn files with some 3D lines/polylines.
How can i check if these lines are close (lets say within 4 m from surface)/under/touches the surface created with pointcloudsurface?
Best answer by danilo_fme
Hi @loganj,
Did you try to use the transformer NeighborFinder?
Thanks,
Danilo
