Archived
Refresh individual datasets in Inspector
Related products:Transformers
jelle
When pushing the refresh button in the Inspector, it refreshes all data sets. Sometimes, you want to refresh one data set only. The idea is to add 'Refresh Dataset' when you right-click on it. Similar where you find the possibility to 'Remove Dataset'.
