***Note from Migration:***
Original Title was: Data Inspector: Changing Background map (or turning off) option to not reset view
Using the 2020.2 data inspector is a joy. The recent improvements with the background maps are amazing!! Having the ability to background high res 2-4 cm imagery is a great QA tool for doing detailed heavy cad-gis with lots of schematic level detail. Not sure if this is already suggested elsewhere or a bug. When reviewing data zoomed in to building level, it would be great to be able to change the background map or turn background off without the data inspector resetting the view to full extent.
I notice the Refresh view operation keeps the viewport the same so maybe this is a bug.
Bonus items:
- have an option to keep or share the viewport between views (tabs) so that switching tabs would enable easy back and forth visual comparison.
- tie this "shared viewport" functionality into saving views and/or arranging views (tabs) as side-by-side panes would be a great tool for comparing datasets in different views with common and differences jumping out.
NOTE: Im providing this feedback using DI in standalone mode (not within WB).
I can provide some better use cases for saved/shared viewport with a bit more digging and experimenting within workbench; I suspect this may also lend itself to data management in general.
Best, Reed
