Can FME read and write Microstation RedLine files?
  • December 8, 2016
  • 15 views
fmelizard
Forum|alt.badge.img+17
A RedLine (.rdl) is essentially an empty MicroStation file that references the DGN file. It's used to 'markup' a layer that appears on top of the contents of the DGN file without actually touching / changing the DGN file.
daveatsafe
Forum|alt.badge.img+19
  • December 8, 2016
Yes, FME can read and write RedLine files using the Microstaion v8 reader/writer.
Attached is a simple workspace to create a new RedLine file for any DGN file. When you open it in Microstation, the target DGN file will already be attached as a reference.
