I am getting following error while executing the workspace on FME server. However, workspace is working fine on the Desktop. Please suggest.
The error number from ArcObjects is: '-2147221230'. The error message from ArcObjects is: {}
Best answer by nitinshahane
Hi @ni3 ,
If the data is the same and the database your reading form/writing to is the same database then I might take a look at the ESRI application being used, but I would verify if not a data issue first as that seems to be issue in this issue. In some cases if you use ArcPro library to generate a database inserting into it with and ArcMap library will cause issues. Assuming your FME Server is using ArcGIS Server application and license please make sure that either arcMap runtime has been installed on ArcGIS Server if you are using ArcMap from the desktop, and make sure the ESRI ArcGIS Compatibility is set to a specific value (ArcMap or ArcPro, not auto) in both the FME Desktop and FME Server.
Thanks for the response. I will check the suggested settings. However, the issue has been resolved by downgrading the feature class by removing the ArcFM component.
