I wanted to print the workbench below in A4 paper size in pdf file but it appears that there is no sufficient tools to better layout it in the A4 paper (having it centered, etc.)
How this can be implemented in FME?
I am not if there is a tool to export the model directly as jpg file the same way we do in the model builder of the ArcGIS
Thank you
Best
Jamal
