Counting combinations of 2 overlapping circles
Hello community,
I have a set of circles as shown in the picture below, and I wanna count the number of overlapping circles two by two. which means whenever there is overlapping couple of 2 circles there is an overlap to count.
For the example below, the result must be 6.
is there a way to do it ?
Best answer by jdh
I'm assuming you don't want the number of overlaps for a given segment, but rather the unique combination of overlapping pairs.
I didn't quite have time to finish this before the long weekend, but all that really needs to be done, is in the PythonCaller change the print statements in the close method to creating a new feature and adding the attributes.
countoverlappairs.fmw
danilo_fme
Forum|alt.badge.img+45
  • May 18, 2018
Hi @lianaolianov,
Did you try to use the transformer AreaOnAreaOverlayer?
This transformer generate a attribute = _overlayer.
Thanks,
Danilo
jdh
Forum|alt.badge.img+28
  • May 18, 2018
danilo_fme wrote:
Hi @lianaolianov,
Thanks,
Danilo
Hello,
I tried this transformer but I wasn't getting the results I want, more combinations were counted.
Hello,
Thank you for your answer, I've seen the workspace but i didn't know how to use it properly, i've never used Python in FME nor elsewhere. How can I get the wanted result from it ?
  • May 19, 2018
Hi @lianaolianov, This is an alternative without Python scripting. FYI.
count-overlap-pairs-without-python.fmwt (FME 2018.0.0.3)
Thank you very much
It works fine :)
