Parallell processing - licensing issues
  • September 30, 2016
  • 6 replies
  • 6 views
sigtill
Forum|alt.badge.img+24
I seem to be getting the same issue as described here: http://gis.stackexchange.com/questions/22427/fme-error-failed-to-validate-fme-worker-licence-key
After the same amount of time I get "Failed to validate FME worker licence key" - after approx processing 1 000 000 objects. I need parallell processing due to the size of the data, I have tried Aggressive only, and also Extreme.
Below is a screenshot showing part of the process. The Parallell runs in Parallell (:)).
After approx 1hour 20 minutes the logfile fills with "Failed to validate FME worker licence key" and the fmeworker.exe gets stuck with no work done (0.01 percent CPU constantly).
I use FME 2016.1 - floating license - Oracle Edition.
Also tried on FME 2017 - same issue
@Mark2AtSafe
sigtill
Also tried it on FME 2017 - same issue.
sigtill
It seems when they are run in Parallell the Parallell 2 try to start before all processes of Parallell 1 is finished. Putting a FeatureHolder after FeatireWRiter 2 and directting the summary from FeatureWriter2Holder to Parallell 1 seems to solve the issue so that there is a license free when Parallell starts the second time.
So the issue is that if one Parallell Processing custom transformer is only finished with X-1/X processes when the second Parallell Processing custom transformer tries to start 1/X processes it crashes. It seems all of the processes of a Parallell Processing custom transformers needs to be complete and done before a second Parallell Processing transformer can try to start even a single process.
This can be solved by making sure a featuerholder is used somewhere between the 2 Parallell Processing transformers
sigtill
  • October 4, 2016
I have now filed C120198 for this, attached logfile, workspace and screenshot. I have made sure the Parallell is run after each other by using a FeatureHolder inbetween. So everything is "free" before a new Parallell runs.
martinkoch
Forum|alt.badge.img+18
  • February 22, 2018
Has the issue been resolved yet in a newer version of FME? I have exactly the same problem using build 16494 - WIN64. I tried searching for PR#43805 and C120198 but I keep finding only this post.
I use parrallel processing in writing to an Oracle database. All works fine on a fast FME machine with a fast licence-server and a slow connection to Oracle. On a slow machine with a fast Oracle connection it fails after about this 1 hour and 20 minutes.
mark2atsafe
Forum|alt.badge.img+44
  • February 22, 2018
That PR number is marked as closed-fixed. It was back-ported to a newer version of FME2016 - build 16709 (2016.1.3 branch) - so if you give that a try I am hopeful it will work. If not, please do let us know.
martinkoch
  • February 26, 2018
Thanks Mark. Unforunately I am stuck at the current build due to the update policy at this client. Waiting for 2018.1 for this one...
