Problem PythonCaller when workspace run from folder with accent
Since I upgrade to FME 2016, I have the following error when trying to use a PythonCaller in a workspace that is in a folder with accent such : /Testé/
Error adding `H:\\FME\\Decoupage_Secteur\\Testé\\' to the python path
Python failed to initialize
If I remove the accent in the folder name, the workspace run without error.
FME should try to write the path like this:
H:/FME/Decoupage_Secteur/Testé/ to avoid error
Is it normal or a bug? In previous version of FME there was no such error.
Best answer by takashi
Hi @burton449, it's a known bug in 2016.0. The same error occurs for Japanese characters, and I heard that it will be fixed in 2016.1 from Safe.
# I hope that the fix will be backported into 2016.0.1.x.
  • February 18, 2016
mark2atsafe
Forum|alt.badge.img+44
  • February 19, 2016
I've asked the development team if they can fit this into a 2016.0 fix/service pack (if there is one). I'll let you know what the say.
fmelizard
Forum|alt.badge.img+18
  • February 21, 2016
Just checked and this fix is going into the 2016.0.1.1 micro-update due out in the next 10 days.
  • February 21, 2016
Hi @daleatsafe, @Mark2AtSafe, good to hear. Thanks for your every effort on i18n of FME.
Forum|alt.badge.img+5
  • February 22, 2016
Hi,Bonjour,
In your Python Caller, you can add this line # -*- coding: utf-8 -*-
The Workbench runs successfully.
import fmeobjects
# Template Function interface:
# When using this function, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
def processFeature(feature):
    pass
# Template Class Interface:
# When using this class, make sure its name is set as the value of
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        folder = FME_MacroValues['folder']
        print folder
        self.pyoutput(feature)
    def close(self):
        pass
Bonne programmation !
  • February 22, 2016
julien wrote:
Hi,Bonjour,
import fmeobjects
    pass
    def __init__(self):
        pass
        print folder
    def close(self):
        pass
Unfortunately the encoding declaration did not resolve the issue in Japanese locale. The solution is effective in European locales?
  • February 23, 2016
julien wrote:
Hi,Bonjour,
import fmeobjects
    pass
    def __init__(self):
        pass
        print folder
    def close(self):
        pass
Yes it's for European countries @French
