Add attribute 'Status' during join/merge (i.e. 'joined', 'unjoined_left', 'unjoined_right')
townest
Forum|alt.badge.img+4
Greetings,
Do you have a best practice for adding a 'status' attribute populated with the value of the join status such as 'joined', 'unjoined_left', 'unjoined_right'? I can imagine using a 'create attribute' transformer outside of each join transformer port, but that seems heavy on transformers (four total). Let me know if you have a more efficient solution.
Thank you,
Tyler
Workbench 2022.1
Best answer by dustin
If you right click on the output ports, you can add an attribute and set the value as needed. image
dustin
Forum|alt.badge.img+30
  • December 21, 2022
townest
  • December 21, 2022
@dustin​ ,
Good tip. Thx.
Why are my expansion arrows red now?
imageTyler
dustin
  • December 21, 2022
townest wrote:
@dustin​ ,
Good tip. Thx.
imageTyler
@townest​ That's an indication that an attribute is being created in the port.
townest
  • December 21, 2022
