Select Distinct values Oracle Reader
dustin
Forum|alt.badge.img+30
I have an Oracle database with about 500,000 entries. I want to read in 1 feature for each unique value of 'DEVICE_TYPE'. Is there a select or where clause I can use to do this?
Best answer by david_r
The most efficient will be to use an SQLExecutor rather than a reader for this, e.g.
SELECT DISTINCT DEVICE_TYPE
FROM my_table_name
If you want it to be as fast as possible, make sure that "DEVICE_TYPE" is indexed in the database.
For larger datasets, this will be an order of magnitude faster than reading all the data into FME and then using the DuplicateRemover.
  • August 11, 2022
FROM my_table_name
dustin
  • August 11, 2022
FROM my_table_name
Thanks @david_r​, this was very helpful.
