How can i convert date from dd.mm.yy to yyyy (4 digit only ) in column in excel
  • January 30, 2020
  • 12 replies
  • 110 views
soly
Forum|alt.badge.img+3
as example 01.02.2000 to 2000 only
Thanks
erik_jan
Forum|alt.badge.img+26
  • January 30, 2020
Have a look at the DateTimeConverter transformer.
umapper1
Forum|alt.badge.img+5
  • January 31, 2020
Could you not also use a text string function to strip the preceding characters, retaining just the last 4 digits?
soly
  • January 31, 2020
i found the problem ,it reads last examination as char but it is in column date as 20.06.2019
do you have suggestion to convert from char to date .
i tried to convert char type to date type manual of the reader but it does not work also but i need a way to do that automatically in correct way bcs all my excel files have the same issues .thanks
soly
  • January 31, 2020
what u mean about string function ,i do not have transformer in fme 2018 for that .thanks
i think ,this is my problem bcs i did another column called date ,it shows that type is date and i get output but old colzumn that what i need last examination ,the type is char so i did not get any output.i need to convert from char type to date automatically .thanks
  • January 31, 2020
@soly DateTimeCOnverter should work. Try an input format string of %d.%m.%Y$
erik_jan
  • January 31, 2020
If it is a Char where the year is always the last 4 characters, the SubstringExtractor transformer (from -4 to -1) will result in getting the year.
soly
  • January 31, 2020
thansk for reply i got ur idea but i checked the output on inspector and it is the same as input no change
input excel file
i choose source string the column that i need
outüut inspector is still the same ,
do u have another solution or what do u think which wrong or do we have way to convert tye attribute .thanks
soly
  • January 31, 2020
thanks but i did it and it does not work with me
could you provide me an example of work space if u have time but make the input as char for date and thanks i need only the last 4 digit only the year
erik_jan
  • January 31, 2020
input excel file
End index should be -1 instead of 1
soly
  • January 31, 2020
m.xlsx
please this is the excel file.could u try by ur self and let me know,how can i convert last column that include char .i know ur idea by substring,it should be correct but it does not work with me .i do not know the reason and i changed the index and it does not work .thanks for helping
erik_jan
  • January 31, 2020
m.xlsx
Here is the solution:
And the workspace:
Date_to_Year.fmw
Hope this helps.
soly
  • February 2, 2020
And the workspace:
Date_to_Year.fmw
Hope this helps.
thanks alot
