how to change exact multiple words in StringPairRepacer ?
  • January 7, 2020
  • 10 replies
  • 84 views
tomjerry.vl
Note: only change exact word not combination words .
it posible change exact multiple words in StringReplacer and StringPaireReplacer
rock=Star
nove=9
RAW sourceNormalized
nove9correctnovember9mberincorrectrockStarcorrectrockstarStarstarincorrect
bwn
Forum|alt.badge.img+26
  • January 7, 2020
With StringReplacer, you can use Regular Expression mode to be a lot more flexible in what is allowed, and what is not allowed, to be replaced.
You can test it in any number of online Regular Expression testers like:
https://regexr.com/
https://regex101.com/
For example, using a regular expression test = \\b[N|n]ove\\b in StringReplacer will restrict replacements to where only "nove" or alternatively "Nove" is a word by itself. The "\\b" expressions are placeholders for word boundaries such as the space character or the start of line or end of line characters. So whilst "nove" would be match, using the above regular expression "november" would not, because the letter "m" is not a word boundary character.
Unfortunely StringPairReplacer cannot use Regular Expressions, but one method may be to instead use a pre-processor like StringSearcher, which can use Regular Expressions.
With StringSearcher you could use \\bzero\\b|\\buno\\b|\\bdue\\b.... to find any words that are "number words" (the "|" expression is the equivalent of "or") and separate this out as their own string result number words. Then you could use StringPairReplacer on these results to replace the "number word" with its equivalent digit and then merge this result back into the original string at the place within the original string.
  • January 21, 2020
You can do this with just two transformers, a Tester and a StringPairReplacer. If you have a list of the words you can make a comma separated list of them for the Tester, using the In operator and set Comparison mode to Case insensitive if that is correct for you. Then you send the features that passed the test into the StringPairReplacer where you do the substitutions. The features that didn't pass should be led outside the StringPairReplacer and join the substituted features afterwards.
tomjerry.vl
  • January 22, 2020
it is work for exact words but I have combination words
like
novenove ratnagrd rock novegrd nove ratna novembernovembergrd nove ratna
note: I have to change for roman number
check below it is for roman number Vi (6) and give betterment and for bulkwords also
Stringpair_replacer.fmw
tomjerry.vl
  • January 22, 2020
https://regexr.com/
hi @bwn i tried but getting confusion please give berif and if possible check above comment, fwm and adjust for bulk words
  • June 3, 2022
I would like to use StringPairReplacer, but I cannot figure out how the pairs are entered. In curly brackets, i.e. a dict in Python? In any case, the documentation should include an example. Thanks!
danminneyatsaf
Forum|alt.badge.img+13
Hi @bradosav​ The pairs are entered as just separated by a space. For example:
if the source attribute’s value was:
bobby
and the replacement pairs were:
b s o a
  • b will be replaced by s
  • o will be replaced by a
the result will contain:
sassy
You can find some examples of how to use the StringPairReplacer in the documentation under the General header.
geomancer
Forum|alt.badge.img+60
  • June 7, 2022
You may also want to take a look at this question, where some possibilities are discussed that are not currently in the documentation.
  • June 9, 2022
bobby
b s o a
sassy
Thanks, exactly what I was looking for!
  • June 9, 2022
Thanks! One of the screenshots in the question you referred to had the answer!
geomancer
  • June 9, 2022
You're welcome, I'm glad I could be of help.
