Can I let FME Desktop use Resources over Hadoop?
  • June 28, 2014
  • 34 views
Hello everybody!
I'm asking, if it is possible to use a Hadoop Distribution on FME Desktop's work.
On one side, for storing input and output files but more importantly for sharing the cpu-usage of a translation into multiple Hadoop tasks on multiple Computers.
I'm working on a project right now where the tranlation with 100.000 lines takes about 45 minutes.
I can only imagine the time it will need on about 1.200.000.000 lines if I'm computing it on a single computer.
Thanks for reading!
PS
So far I'm only working on FME Desktop, I watched some Youtube Videos about FME Server and could imagine that it could work with Hadoop quiet well.
Best answer by david_r
I have never heard of anybody using Hadoop with FME, but it would certainly be cool to hear a success story with that kind of technology! That being said, I suspect it'd be easier to just use regular FME Server functionality to accomplish the same thing (splitting a process over several enginges, distributed over several servers)
For the idea about Hadoop, just be aware that you'd probably need a separate FME Desktop license for each server...
David
  • June 30, 2014
David
richardatsafe
Forum|alt.badge.img+10
If you want to test the beta you can certainly use Hadoop for storing input and output files with HDFSConnector, but as far as parallel processing goes David makes a good point: FME Server will allow parallel processing with multiple engines on multiple machines.
https://knowledge.safe.com/idea/54272/working-with-hadoop-hdfs-preview-fme-2018.html
danilo_fme
Forum|alt.badge.img+52
  • October 4, 2017
@RichardAtSafe this is very interesting news!
