Can i filter out similar feature names?
I have a load of features with an numeric code as a name, for example 123. When there is an updates version of this example is is 123A, then 123B. What I am trying to do is filter out 123 if there is also a 123A or a 123B, and filter out 123A if there is a 123B. I suppose I need to use a test filter to separate out thos that contain an A and thos that contain a B, but I've no idea what to do next. Any suggestions?
