Fanout Question
  • August 19, 2025
  • 52 views
probert1968
Forum|alt.badge.img+5
I need help how to use Fanout and not sure if this is a bug or not.
Using Workbench 2024.1.1
  1. Using DWG as a reader and then change the parameter to Geometry and selected lines.
  2. Add the AttributeFilter to import the feature cache type
  3. Add the data as a writer to write new feature name.
Am I doing something wrong or need some tweak work ?
Best answer by crutledge
Hi ​@probert1968
Are you trying to read a dwg with all the layers and then write out the geometry types or layers to another file format, like shapefile or features in a filegeodatabase? Fan out can be used on the writer in the screen captures below: (I used a an autocad writer but does not have to be)
The variable attribute is used to “Fanout” the file names and thus separate the content into different files. Hope that helps!!
probert1968
  • August 19, 2025
Never mind. I got it to work however, if you see something different than I do then please post it here…
I had to type in a new filename with an extension to make it work…
For example
crutledge
Forum|alt.badge.img+44
  • August 19, 2025
Hi ​@probert1968
probert1968
  • August 19, 2025
@crutledge   yes
That work !
