Microstation cells not honoring colors assigned in FME extract?
  • June 28, 2023
  • 12 views
jcox
Hello, I am new to FME and am taking over support for our FME extracts between Smallworld and MicroStation. I am seeing an issue where MicroStation is not honoring the colors I am assigning in the .fmw file. I tried the Level Overrides setting and that was not the cause. I seems to be an issue with the cells themselves, but I am not sure. Other cells seem to work fine but I am so far unable to make a distinction between the ones that work and the ones that don't. Hoping anyone has encountered a similar issue-- any information is appreciated.
evieatsafe
  • July 6, 2023
Hi @jcox​ thanks for your question! Are you able to provide a sample of data and a workspace to reproduce this? I haven't encountered this, but additional information could help anyone else looking at this thread. Thanks!
